Reload this Page >
C-ARF Ultra Flash build Thread + Video
Old 10-27-2019, 09:09 AM
  #6251
cbk07
My Feedback: (64)
Thank you Dave
Old 10-30-2019, 07:16 AM
  #6252
Dave Wilshere
Old Video of an Ultra Flash flown standard speed!
<iframe width="1024" height="768" src="https://www.youtube.com/embed/Hm7zVoRzIeM" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Old 10-31-2019, 01:29 PM
  #6253
AEROSHELDON
My Feedback: (99)
AEROSHELDON's Avatar
How are you all doing a Jet Central with the plug that sticks down? I have a new Lynx 130 because I wanted a lighter not as fast jet, but this hits the wing when I try to bolt it on.....
see -->
plug hits.....
Old 10-31-2019, 01:33 PM
  #6254
Dieselman1220
My Feedback: (25)
Dieselman1220's Avatar
Just rotate the engine on the straps a little, get the plug to the 4 or 7 o clock position
Old 11-03-2019, 06:11 AM
  #6255
scoeroo
My Feedback: (9)
scoeroo's Avatar
Turn the whole turbine 180 ....easy , have the plugs facing toward the canopy side
Old 11-03-2019, 06:40 AM
  #6256
AEROSHELDON
My Feedback: (99)
Jet Central said I could rotate 45º so I just rotated little and the wire is now out of the way. Thanks for the suggestions.
Old 11-16-2019, 10:09 AM
  #6257
Dieselman1220
My Feedback: (25)
Got my Swiss scheme Evo in yesterday. Very impressed with the level of pre fabrication done.
Just enough in my opinion as I still enjoy some assembly. Gear looks nice and stout.
Mine will be powered with a Jet Central cheetah 140 also planning on lights and smoke.
Old 11-16-2019, 05:32 PM
  #6258
paulhat
Would be great to see some pics
Old 11-16-2019, 06:50 PM
  #6259
AEROSHELDON
My Feedback: (99)
Congrats. I saw a Swiss fly today and they look great.
Old 11-16-2019, 08:30 PM
  #6260
Dieselman1220
My Feedback: (25)
Only got these, it will be a few weeks before I begin the build.
Gear doors already done..the spring is a nice touch.
Trays already done
Old 11-16-2019, 11:57 PM
  #6261
paulhat
Wow... that is super nice. Love how the tray is all ready to go.I think your dog loves it as well
Old 11-17-2019, 02:53 PM
  #6262
Dieselman1220
My Feedback: (25)
Haha she's 13 years old now, nothing excites her except food and sleep
Old 11-18-2019, 07:45 PM
  #6263
JSF-TC
JSF-TC's Avatar
Had a scare with my 3yr/136 flight Ultra Flash this last weekend. All was perfectly normal until I lowered full flap on downwind in preparation for landing. The model started to act strangely, wandering all over the sky. I fought it and got it turned around headed back towards me. I then thought to raise the flaps back to mid, and it all settled down to normal. Deciding to land with mid-flap I went around, but with no wind the landing was a little hot and I forced it down, breaking the nose gear mounting plate.
On investigation, the left flap outer glass skin had de-laminated, about 1" at the outboard end and extending inboard about 3/4 of the span of the flap. This then caused the flap to blow back resulting in an asymmetric flap condition.
I have never lowered the flaps at high speed, so apart from general wear and tear I'm not sure what caused this de-lamination. Going to try to inject some epoxy resin between the foam and glass skin and bond it back down. The nose gear plate should be relatively easy to Hysol back into place. This was the first ding on a model that has flown perfectly for 3 years. On reflection, with a short field and no wind, I should have gone around and set up for a dead-stick landing and killed the engine on finals. I was a bit behind the model, especially when it started acting up. It normally flies on rails, so lulled into a complacent mid-set.
Something to check on a pre-flight - I'm normally thorough, but not sure I would have noticed the de-lamination without specifically looking for it.
Paul
Old 11-18-2019, 10:05 PM
  #6264
Dave Wilshere
Normally something like that would be from transport or storage, but even someone catching it with their foot could have done it.
Dont use thick epoxy, there will be no void to fill. I would use ZAP 40 finishing resin painted in there with a brush. Also get a tube of grease and run a line along the hinge line inside, so if the epoxy squidges out it won’t seal the hinge tape.
One all my jets a full flap pull/load test on the flaps is a normal pre take off check. Seen too many people roll a model on its back coming in for a slow pass/landing and deploy the flaps only to find one was jammed/broken or servo lost its power.
Old 11-19-2019, 05:28 AM
  #6265
txshan130
My Feedback: (114)
txshan130's Avatar
With hundreds of flights on our multiple Flash jets, that is always a concern. I fear it's not if, but when that will occur one day. We are super careful during transport and storage, but even then you can't always be 100% sure the flaps haven't been knocked around a bit. Even in full-scale aircraft, if you make a control change that adversely affects flight, reverse what you did and then investigate... A no-flap landing isn't the end of the world.
Old 11-19-2019, 07:05 AM
  #6266
AEROSHELDON
My Feedback: (99)
I witnessed a few EVO landing gear that the mains twist a little and then the gear hangs up. Would anyone suggest preventative maintenance on them? Flat spot and loctite for example?
Old 11-19-2019, 07:53 AM
  #6267
Dave Wilshere
They just need to do the clamp up fully. From the factory they are only 'nipped' the toe in needs setting and clamp screws tightening.
Problem of ARTF models...
Old 11-19-2019, 09:25 AM
  #6268
AEROSHELDON
My Feedback: (99)
Old 11-21-2019, 01:06 PM
  #6269
Dieselman1220
My Feedback: (25)
Just curious has anyone done nav lights out on the wing tips of an ultra flash? Just wondering if it will be possible to fish the wires from
the wingtip to the aileron/flap servo bays?
Old 11-21-2019, 03:39 PM
  #6270
Dave Wilshere
Never done it, but memory says the rib has a cut out, so should be possible.
Old 11-29-2019, 08:32 PM
  #6271
ucandoit
My Feedback: (27)
So I bought a buddy Ultra flash and it had Smoke and it used the wing tank for the smoke oil . The header tank and saddles where used for Turbine gas . So my question is i'm taking the smoke out and was going to use the header tank and wing tank for turbine gas to keep the CG close . I was thinking if I used the saddle tanks it further behind CG and wouldn't be as good as the wing tank .
Wanted to get your guys opinion on what you guys would use far as tanks ? Am I on the right track Thanks for any help and thanks Scott K
Old 11-29-2019, 11:50 PM
  #6272
cmjets
cmjets's Avatar
Hello, yes, you can, I have a customer that use the wing tank like last tank before UAT, the rest of Tanks you can connect they in serial or saddle in parallel with serial with main and wing.
I have installed in mine a only bigger main tank. EVO +, with 4L.
Regards from Spain.
Carlos
CMJETS.com
Old 11-30-2019, 08:38 AM
  #6273
Dave Wilshere
stock wing to fuselage to bubble trap works perfectly if you use hi-flow clunks. The saddle tanks don’t move the range excessively, I have one customer using all 4 tanks! Long flight times...
Old 12-01-2019, 04:07 AM
  #6274
hotspot 01
I used all 4 tanks to get extra flight time but the extra two minutes wasn’t worth the extra connections and take off weight now back to saddles and main tank 190sv from start to end of 6.5 minute timer 800ml left.
Old 12-22-2019, 05:52 AM
  #6275
Canadian Man
Canadian Man's Avatar
In case your interested. Swapping a Fuselage on a CARF Ultra Flash.
