FokkeRC 1/5 Spitfire MKIX build log
#376
While waiting on blisters to cure began on the wing tip nav lights and frog eye fairings as well as the browning .303 shrouds.
David Glen(Warbirds in my Workshop) gave me a great idea on building the fairings. His work is insanely beautiful and worth taking a look at.
#377
I’m about finished up with the Hispano cannons and nav fairings, some light sanding to do yet. Jiri at JPWarbirds is printing elliptical cannon shrouds for me as the current ones are the narrow early model variant. Hopefully today I can mount all the blisters on upper surface. Then I can get going with riveting and panels.
#378
Your work continues to impress! Coincidentally, I just checked in with Jiri 2 days ago with a question - and he responded overnight! I used Rumen’s cannons, which had a lot of 3D printing rings to sand and fill and sand and fill and …. LOL. Either Jiri’s come with a super finish or you sanded and filled and sanded and … Looks great! (I decided to go Isaac Najary’s direction and make them detachable which gives an obvious seam vs your seamless finish). Given the first crash they’ll detach anyway, I thought I’d pre-empt haha!
I just decided last night to have Jiri make the blisters for me along with the seat back structure which I forgot when ordering the seat. BTW, to your thread followers, his work is excellent quality and he is super to work with.
My skilled paint work before this project was a 1” cutting in brush. Now I am detail painting cockpit parts using what looks like a single whisker off a squirrel!
So I’d like to ask a question of you and your followers. (Be gentle as I am a newbie way out over his ski’s!). I realized I cannot do wing fairings without skinning the fuselage. And it makes more sense to do the much MUCH delayed cockpit before I skin. So my questions: Did you use Jiri’s printed paper gauges for the cockpit dash or other supplier or ….? And did you source plastic circles for guage covers? I am not looking forward to cutting out the circles with scissors and don’t know of a better option, so open to ideas. Thanks!
#379
Findgareth (01-17-2024)
#382
Finished up mounting blisters and cannons today, the barrels I have on in the photos are the early variant, but I wanted to see them on. Also started laying some paneling. Hopefully I’ll be able to start in on the rivets soon.
fokke (01-24-2024)
#385
It has been a bit since I’ve posted any progress, finished up radio install and batts, detailed the gear, spinner and began paint prep. I’m using warbirdcolors and so far I’m enjoying them. They thin out nice for both my badger detail airbrush or my hplv. Hoping to finish the base coat completed in next few weeks then washes, weathering and detail.
fokke (04-23-2024)
#386
Began spraying the upper surfaces earlier this week, layed down the middle stone fields first then the dark earth, had some headaches with the foam soft edge tape on the first round but was able to revisit the edges on subsequent coats. Still revisiting some areas, then on to paint masks for roundels, nomenclature and weathering.
#390
The left hand fillet blister just aft of the gun camera hatch was so the skin could clear coolant piping.
This the one you were referring to?
Wyoturbine (Yesterday)
#392
Touched up the underside this evening, I haven’t re-attached the lower cowl quite yet, just wanted to match it up with wing and tail. Also was finally able to pull the canopy tape, which had been on the lexan for over a year, frog tape low tack left surprisingly zero residue, so hats off to them.
