Welcome to Club SAITO !
Old 01-03-2009, 10:21 PM
  #13426
s10junky83
Default RE: Welcome to Club SAITO !
I guess the vibration was because it was hard mounted to my stand. It is still alittle juicy but that front bearing is leaking like crazy! Any suggestions?
Old 01-03-2009, 10:44 PM
  #13427
w8ye
My Feedback: (16)
w8ye's Avatar
My experience with the rubber sealed bearings is that some of them do not fit tight at all, In fact. you can see light through them.
I don't know if they were this way from the factory or is it the result of heat applied to the crankcase to insert the bearing.
I have a 56 that is juicy out the front since I put new bearings in it. In fact it is the second set. Two years ago I put bearings in it and you could see light under the seal lips.
So last winter I put another set in it and while I don't see light under the seal lips, the engine blows a lot of oil out the front. Now I've used the devil out of it. Run a 13-4 APC and s turbo header. It really hasn't changed any in two years. It was a used 56 I bought at a swap meet so other than me giving it the business for two years I don't know much about it. It may have always been juicy?
Old 01-03-2009, 10:56 PM
  #13428
s10junky83
well, thanks for the everything couldn't have done it without this forum! I sent a email to rc bearings about this becuase it is rather irritating that I have a beautiful plane and don't need it covered in oil.
Old 01-04-2009, 03:01 AM
  #13429
w8ye
My Feedback: (16)
w8ye's Avatar
Back about 5 years ago I came across two well used first edition Saito 91S engines from different parts of the country. I had to rebuild both of them.
One blew oil out the front bearing and the other didn't. I always used the "wet" one. It ran mighty good but sprayed oil out the front. The bearings came from the same place.
Old 01-04-2009, 12:37 PM
  #13430
mike early
mike early's Avatar
Sometimes it seems the bearing seat in the front of the crankcase gets a little loose, for perhaps a variety of reasons. I just know that mine did, and I sent angry emails to the bearing company. They never replied so I presumed they agreed it was their fault that my engine leaked oil and I had some axial play when the engine was hot.
One day I 'shimmed' the front bearing with aluminum foil and ran the engine. No oil and no axial play when hot. The aluminum foil did not last long and it leaked again.
I crashed the plane and broke the carb mounting tab. I bought a new crankcase and the bearing was surprisingly more snug in the front and no oil and no axial play.
Old 01-05-2009, 05:26 AM
  #13431
Rudolph Hart
Rudolph Hart's Avatar
Does anyone here run du-bro soft mounts on their saitos,and if so why.I'm thinking about one for my 220 single.
Old 01-05-2009, 08:59 AM
  #13432
av8djc
ORIGINAL: mike early
Locktite and others make compounds to seat or in fact lightly glue a bearing into wherever you're inserting it. It is not permanently glued. I'd have a look at something like that to try instead of the aluminum foil. It should last a long time.
Dave
Old 01-05-2009, 10:02 AM
  #13433
tz250w
tz250w's Avatar
I'm one of those that likes to shop around... I have two O.S. thumpers (52 and 70U/pumped), a YS 110 and as of yesterday a FA82a Saito. I might add that all of these engines came to me (slightly) used from the same original owner.
Old 01-05-2009, 10:25 AM
  #13434
w8ye
My Feedback: (16)
w8ye's Avatar
ORIGINAL: Old Fart
Often, soft mounts create more problems with the engine's running than they help in dampening airframe vibration
Old 01-05-2009, 12:04 PM
  #13435
mike early
mike early's Avatar
If you boys wanna get rich, try selling your old saitos on Ebay. They go for about the same price as brand new ones.
Old 01-05-2009, 12:37 PM
  #13436
pmillerusa
pmillerusa's Avatar
ORIGINAL: Old Fart
A much smaller engine (.91); I am still finishing the plane, but have a soft mount on the stand now and it will be going in the plane. Feels good on the stand and hoping for similar results in the air...
No expert opinion however, just what I am seeing so far. Your mileage may vary.....
Old 01-05-2009, 01:26 PM
  #13437
w8ye
My Feedback: (16)
w8ye's Avatar
Here are the prices as sold from the auction site in the last month. There were a lot that didn't sell also. Looks like people are selling the big ones and also their old twins they haven't used lately.
Old used 90T $307
(2)NIB older 180Gk $386
newer used 150 $355
Newer used 150 $200
NIB early model 100 $175
NIB older 150 $375
NIB 82 $239.36
Older 80 used $132.50
Older 80 used $127.61
Dirty later 100T $219
Newer NIB 180GK $370
NIB 125 $360
Older nice 56 $159.01
Well used 100 $202.50
NIB 82 $270
Older used 180 $325
Older used 180 $303
Old used 90T $318
Newer NIB 30 $99.95
Old used clean 91 $152.50
Old NIB 270 $405
Old 80 cleaned up $102.50
Old 120 antique clean $172.50
NIB 82 $270
NIB 100 $219.99
NIB 56CL $200
NIB 100 $229.99
Older NIB 72 $230
Old 45 MK II $129.06
Newer used 180 $281.10
Old 170R3 $561.01
NIB 182TDP $455
NIB 125 $306
Nib 125 $242.50
Old 80 $102.50
Used older 150GK $198.50
Nice used 130T $355
NIB 100 279.99
Old 01-05-2009, 01:38 PM
  #13438
mike early
mike early's Avatar
Nib 125 $242.50
Someone got a good deal
Old 01-05-2009, 02:30 PM
  #13439
w8ye
My Feedback: (16)
w8ye's Avatar
Some of those were "buy it now's" but the ones that were bids - there would be like 20 bids.
There was one 150 or 180 that was bid up higher than the buy it now price.
Old 01-05-2009, 02:58 PM
  #13440
timLQ
Hey Saito Guys,
Anyone out there know how to hook up a Saito pump to a 180? I have a Sundowner and the motor has a hard time keeping the fuel in the line. I got the complete pump kit from Horizon, but they have no instuctions. It is the kit with the needle valve assy, the check valve and the 3 way line connector (I don't know what that is for) and works off the tank pressure line. Anyone have a schematic on how to hook up the lines? Thanks!
Tim
Old 01-05-2009, 03:07 PM
  #13441
w8ye
My Feedback: (16)
w8ye's Avatar
We could tell you how to hook it up but the best advice is that you will be chasing your tail to no end trying to get that contraption to work.
Buy yourself a Perry VP20 and bolt it down to the back plate of the Saito and you will have more peace of mind.
You could use the Saito contraption to pressurize the tank so you could use a Cline or Iron bay type regulator. It works well that way.
Old 01-05-2009, 05:38 PM
  #13442
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Jim, you and Dar have the only two Saitos I ever parted with, willingly that is, I smashed a .72 into a concrete rode at Ft. Belvoir and lost a brand new .62 in the woods at Andrews ABF.
Old 01-05-2009, 05:50 PM
  #13443
timLQ
OK, That's what I'll do. Thanks for the advice.
Old 01-05-2009, 07:29 PM
  #13444
w8ye
My Feedback: (16)
w8ye's Avatar
I still have that engine and it looks as good as the day you gave it to me.
I know you have enjoyed your plane
Old 01-06-2009, 05:59 AM
  #13445
Rudolph Hart
Yes i've read that and it's a worry,thankyou.
Old 01-06-2009, 06:05 AM
  #13446
Rudolph Hart
Yes paul i think the same.Had a 62 on a soft mount and smooth as silk with no driveshaft or prop wobble.Upgraded and fitted an 82 on a hard mount.I'm an instant balance your prop convert mate
Old 01-06-2009, 08:24 PM
  #13447
jmcmike
My Feedback: (45)
Can you guys tell me if i go to 25% or 30 heli fuel do i need to reset my low and hi adjustments. Spent some time today setting my 115 up with the cowl off my cub and did not want to put it on if have to readjust. Running 15 cool power
Old 01-06-2009, 09:17 PM
  #13448
w8ye
My Feedback: (16)
w8ye's Avatar
You will definitely need to open the high speed and highly likely the low speed also.
Old 01-06-2009, 09:18 PM
  #13449
mistermnkim
My Feedback: (153)
mistermnkim's Avatar
hey guys i have a fa56 for a scale type build, what size and brand prop should i use?
Old 01-06-2009, 09:21 PM
  #13450
w8ye
My Feedback: (16)
w8ye's Avatar
I have several and my prop of choice is the APC 12-6
If you do not have clearance you may have to run a 11-7 or 8
For vertical performanxe I use a 13-4
