Welcome to Club SAITO !
Old 05-11-2012, 04:34 PM
  #22001
SrTelemaster150
SrTelemaster150's Avatar
Default RE: Welcome to Club SAITO !
ORIGINAL: Homer712
Quick question to those of you that have a lot more experience with Saito then myself. I have two Saito engines, both less then a year old. An FA-62 and an FA-72. In the manual, both engines are listed as having a 7 mm prop shaft. If I use my Fox metric prop reamer and ream out an APC prop to 7 mm, the prop will fit perfectly on the 62, but will not slide onto the 72, even if I try to force it on with the prop nut. To get a prop to slide onto the 72 I need to ream it out to 5/16''. Any one else run into this? Is there a misprint in the Saito manual?
Since 5/16" is about .002" smaller than 8mm I would suspect that your 72 has an 8mm prop shaft.
It may well be that although they both have 7mm prop nut threads, they do not have the same sized shafts.
Old 05-11-2012, 05:05 PM
  #22002
KenD
My Feedback: (65)
The FA-72 prop shaft is 8mm, the threaded portion is 7mm.
Old 05-11-2012, 05:10 PM
  #22003
Homer712
My Feedback: (17)
Boy, this is always the place to come for answers. Thanks guys. I reamed out an APC prop to 8 mm and it slid onto the 72 nice and snug.
Old 05-11-2012, 10:35 PM
  #22004
Ernie Misner
Ernie Misner's Avatar
If I remember correctly the 72 and 82 do have 7mm threads but the prop itself sits on a larger shaft where the threads end. You just have to keep on reamin'......
Ernie Misner
Old 05-12-2012, 03:38 PM
  #22005
mike early
mike early's Avatar
The cylinder wall and the piston on my .91 are scored in one small area. Is the cylinder wall coated with some other metal? Or can I try to buff it out?
Old 05-12-2012, 05:32 PM
  #22006
SrTelemaster150
ORIGINAL: mike early
Is it scored or does it have streaks?
If you can't feel it W/a fingernail it isn't scored.
If it is scored, it's toast.
The cylinder wall is hard crome plating over aluminum. (AAC aluminum piston/aluminum cylinder/chrome lined bore)
Old 05-12-2012, 05:33 PM
  #22007
orthobird
just installed my new saito fa 100 GK on a twist 40.
what a beauty.
turned engine on, very easy.
what a beautiful sound
running 15% nitro with 19% oil
pics to come.
Old 05-12-2012, 05:37 PM
  #22008
orthobird
maiden flight this monday, weather permitting.
this is my second saito engine.
ID:	1762020   Click image for larger version
Old 05-12-2012, 06:02 PM
  #22009
mike early
mike early's Avatar
ORIGINAL: SrTelemaster150
It's toast. can feel it with finger. far worse than what a fingernail requires...
Old 05-12-2012, 07:45 PM
  #22010
SeamusG
SeamusG's Avatar
Should I be concerned ...
During the disassembly of my Saito FA-82a I removed the drive flange and tapered collet. A gentle tap of the exposed threaded shaft of the crank end on a soft composite wood surface freed the crank from the case. The main bearing came with the crank. It's very easy to seat the crank/bearing into the case and remove with my fingers. Both bearings turn smoothly and without noise.
Like I said - should Ibe concerned?
Old 05-12-2012, 09:27 PM
  #22011
FNQFLYER
Had a YS 63 like that once (being the operative word).  The bearing spun in the case and the rest is history. If it isn't a firm to tap fit I use some locktite glue on it and then guarrenteed not to cause a problem.  When you buy the locktite also buy a bottle of debonder saves tears later on
Old 05-12-2012, 10:03 PM
  #22012
Ernie Misner
Saito 100 on the 40 size Twist??? Far out man! .... but will it balance? Watch out for that plastic spinner on a powerful 4-stroke. Don't stand near by and wear your safety equipment. Let us know what it's like with all that power.
Ernie Misner
Old 05-13-2012, 03:22 AM
  #22013
Rudolph Hart
Rudolph Hart's Avatar
You are so funny ernie,safety equipment in a fun zone??
Old 05-13-2012, 04:53 AM
  #22014
orthobird
yes, still slighlty tail heavy at 4 inches aft from LE, but at 4.5 inches, it balances out.
there is a post in rc universe that i stumbled upon last night where someone did same combo.
http://www.rcuniverse.com/forum/m_60...tm.htm#6048470
Old 05-13-2012, 08:38 AM
  #22015
mudboger07
Ineed some info from the experts, A friend has a brand new saito 125 that will not complete one flight without the valves coming out of adjustment, we have readjusted them both intake and ex, flew one flight and they are out again, we disasembled the top end cleaned and even added lock tight (blue) and still they come out of adjustment, does anyone have any ideas why this would happen?
Ken
Old 05-13-2012, 08:47 AM
  #22016
JohnB96041
JohnB96041's Avatar
Never heard of valve getting out of adjustment that quick. Describe the "out of adjustment" in more detail. I have 3 Saito 1.25 engines. Did the breakin according to the manual, ran about a gallon of fuel through the engines while flying, adjusted the valves and have not had to do it again, so far. Three years of flying. Are you sure that you are adjusting the valves according to the manual? Did you set the lock nut after adjusting? Was the gap still what is should be after locking the lock nut? The settings can slip when tightening the locknut and it will open the gap.
Old 05-13-2012, 08:57 AM
  #22017
mudboger07
ORIGINAL: JohnB96041
Hey John, This is the first one we have had do this, and we both have quite a few saitos, we made sure after sdjusting the valves they were still in adjustment, we set the lock nut and rechecked. The gap was the same after setting and after seting the lock nut, sometimes it will hold for one flight but most of the time after just a few minutes it comes loose the the point there is over a 60 thousand gap I dont have the manual in front of me but if i remember correctly they set at 4 thousants. also the lock nuts are not loose or any other part of the valve train is loose, Im starting to wonder if something liek the rocker arm is bending? I do know the push rod is straight.
Old 05-13-2012, 09:14 AM
  #22018
JohnB96041
JohnB96041's Avatar
Just a thought. If you have had the push rods out of the engine, were they put back in the same direction. I don't know is there is a difference in the ends of the push rods, but there could be. I would call HH tech support and get some help. A cracked rocker arm would really do the trick. You should be able to see if the rocker arm is bent or bending. Look for a crack on the bottom side of the rocker arm near the retaining pin.
Old 05-13-2012, 10:09 AM
  #22019
mudboger07
Will do John, its stumped us too, both of us are really good at engines thats why were so stumped...lol we havent seen anything broke, looked bent etc. its got us totally stumped.
Old 05-13-2012, 10:12 AM
  #22020
retransit
My Feedback: (18)
retransit's Avatar
This may be a bit simplistic, but did you adjust the valves on compression stroke?
Bob
Old 05-13-2012, 10:21 AM
  #22021
SeamusG
SeamusG's Avatar
This is an FA-82a pic to demonstrate the difference in the push rod ends. If the rounded ends (not the pointed ends)were installed towards the rocker arms, no way would (could)they stay in the "hollow"of the rocker adjusting screw. When they become disconnected from the adjusting screw the gap jumps to 1/8" from .0025".
Old 05-13-2012, 01:59 PM
  #22022
mudboger07
ORIGINAL: JohnGilmore
John, ya the pointed in are facing the rocker arms, thats whats wierd, like i said weve never had this kinda issue before, its probably ganna be something simple that were over looking, he just ordered all new valve train parts so well see when he gets back from joe nall.
Old 05-13-2012, 02:06 PM
  #22023
radial1951
Hi Ken
Some thoughts on your problem. Let's assume:
1. At the end of the flight, the adjusting screws and lock nuts are still tight and have not moved. (You might be able to check this by degreasing the parts and trying a tiny dab of correction fluid on the screw, nut and rocker. If it sticks ok, you will see if any component has moved during the run).
2. The rockers aren't brocken, the tips of the valves and rocker tip are not suffering massive wear, and the same for the pushrods i.e. they are the same length after the run.
3. All other engine screws are tight and nothing else is apparently loose.
NOW, the problem moves down to the components activating the pushrods i.e. Tappets (Part 38) ; Cam Gear (Part 35) ; Cam Gear Shaft (Part 36).
If this problem has occurred quite a few times, any wear on those components will be more than obvious!
Regards, RossG
radial1951
______________
ORIGINAL: mudboger07
Ken
Old 05-13-2012, 02:17 PM
  #22024
SeamusG
SeamusG's Avatar
If this were early April (real early) I could understand.
I assembled my 82 yesterday. I managed to get the alignment of the black push rod tube off and at that angle it pushed the push rod sideways in the tube so when the cam lobe pushed up that particular push rod could not travel freely and was pushed off to the side.
When you say "valve train parts" that could be a fairly long list of new bits. What's being replaced?
Old 05-13-2012, 02:32 PM
  #22025
radial1951
Hi Ken
If the engine is brand new, why is your friend buying new parts for it.
As JohnGilmore says, that could be a long list of expensive parts.
It does have awarranty...
Regards, RossG
radial1951
_____________
