Reload this Page >
Weeks Solution 70WS
Weeks Solution 70WS
Old 03-11-2024, 07:25 AM
  #101
altijack
Ok thank you.
Old 03-22-2024, 08:15 AM
  #102
altijack
Out of interest, what was See Temp made of? I had a look online and it looks like a great material.
Old 03-23-2024, 05:18 AM
  #103
Tony Hallo
52"x 22'" x.011" translucent thin plastic that broke on the scored line
Old 03-23-2024, 08:25 AM
  #104
altijack
Ak ok. Maybe I can find something similar. I’ve tried unused chest xray surplus but it doesn’t behave like you describe. Thanks.
Old 03-29-2024, 05:21 AM
  #105
altijack
Can someone please point me in the right direction toward a modern gas engine for the Solution 70”, that will be able to hover the plane?
Also a decent target all up weight. I’ve got some really good contest balsa that I’ll be using. I can usually build quite light. Cannot see anything on the plans regarding weight.
Oh and I’m new to gas and it’ll have to be able to be silenced to pass a noise test from both sides, head on and from behind at 7 metres. 82 decibels. Thanks.
Old 03-29-2024, 05:43 AM
  #106
edp
edp's Avatar
D&B Engines by Ridge Machine
Old 03-29-2024, 07:20 AM
  #107
altijack
Thanks edp. I’ll check out the product and then see if they will deliver across the pond. Any idea of the target weight?
Old 03-29-2024, 10:56 AM
  #108
edp
edp's Avatar
I flew the 77" and the 84" ones. Kenny will be able to answer all your question as he is CNC ing Miles's kits now.
